ND Filters - some help please
sophos9
Dave
Hi,
I would like to buy a set of ND filters however unsure about what I need. I've seen the 2 types, I dont think the screw on ones offer that much flexibility - so thinking about the holder types.
I have 2 lenses to use these on, one is a Tokina 11-16mm and the other is Sigma 17-70 - would I need 2 holder?
Can someone help me spec up something for the lenses please?
Thanks in advance
you would not need 2 holders, if the filter thread size is different then you use a second adaptor ring. What sort of budget have you got? As this will change whet is reccomended, in order of cost cokins, hitech , lee. personally have lee soft ndg filters with a 105mm b&w cpl filter and adaptor ring on the front of a lee filter holder, the total cost for the complete set as listed was approx £600.
Thanks Dave
The budget is cheap and cheerful to play with them - if it works out and I use them a fair bit then I'll upgrade. They are only for casual use :)
Thanks Dave
I would look at the cokin filters for cheaper, make sure you get the latest ones as earlier cokin gnds had a habit of causing a colour cast. do a search for speedgraphics yhey get very good reviews and also offer good prices from what have read.
There's a kood set on evilbay at the moment, i have a set of these and have had no issues with them.
*the link is posted for reference only and i have no connections with the seller
Thanks Dave
After some research on here for a 'starter' filter kit. I am buying the following soon if it is of any guidance.
ND Grads : http://www.teamworkphoto.com/index.php?main_page=product_info&products_id=10288
ND Filters : http://www.teamworkphoto.com/index.php?main_page=product_info&products_id=10355
Kood P-Type Holder : http://www.premier-ink.co.uk/photographic/square-filters/p-type/kood-ptype-filter-holder-p-1256.html
Kood P-Type WA Holder : http://www.premier-ink.co.uk/photog...od-ptype-wide-angle-filter-holder-p-2532.html
Kood 72mm Adapter Ring : http://www.premier-ink.co.uk/photog...type/kood-ptype-72mm-adapter-ring-p-1268.html
Kood 77mm Adapter Ring : http://www.premier-ink.co.uk/photog...type/kood-ptype-77mm-adapter-ring-p-1269.html
HTH
Don't bother with the cokin/kood holders, get the eBay items instead, much cheaper - yes, buy two of them, one for each lens, and cut the front off one of them leaving only one slot; this would be for the 11-16mm so it only takes one filter and doesn't vignette when used at 11mm - lots of folks do the same thing for their Sigma 10-20mm lenses.
There's previous threads on here about it with pictures... worth a thought.
