Michael Batten
- Michael
- No
Does anyone have any experiences of this product as a much cheaper alternative to the Peter Hurley Westcott system?
Hurleys lights are amazingly expensive.
Yes ridiculously so, probably because his name is attached to them, he does seem to think quite highly of himself![]()
The big issue is CRI. LED’s don’t have a very wide colour gamut. Whilst they’re fine for ‘seeing’ they don’t render colours correctly. So ‘better’ LED lights attract a hefty premium.Just a thought having never thought of it before ,but in my caravan awning I have a sabre L.E.D light tube ,this is not only extremey bright but costs just over £30 for the starter tube ,the advantages are it comes with a remote control which gives multiple light levels and you can also buy add on tubes to get even more light .someone with a bit of thought could easily convert this to a studio set up very cheaply indeed .hmmmm
interesting Phil I presume you mean in the way of white balance ,but cannot that be corrected in Lightroom etc ,also can the ice light l.e.d's be bought as a standalone strips as its quite easy to make home made tubes with a bit of d.i.y skills .The big issue is CRI. LED’s don’t have a very wide colour gamut. Whilst they’re fine for ‘seeing’ they don’t render colours correctly. So ‘better’ LED lights attract a hefty premium.
So your £30 sabre LED might look like great value compared to an ice light but it’s not a sensible substitute for pro photography.
CRI is more of an issue than colour temp.interesting Phil I presume you mean in the way of white balance ,but cannot that be corrected in Lightroom etc ,also can the ice light l.e.d's be bought as a standalone strips as its quite easy to make home made tubes with a bit of d.i.y skills .
Color Rendition is the ability (or otherwise) of a light to render colours accurately.interesting Phil I presume you mean in the way of white balance ,but cannot that be corrected in Lightroom etc ,also can the ice light l.e.d's be bought as a standalone strips as its quite easy to make home made tubes with a bit of d.i.y skills .
