papajay
- papajay
Fujifilm X-T3 Vertical Grip
Fujifilm has done something fantastic with their battery configuration in the XT3. They use a medium sized battery to keep the cameras compact, but those that need more power can get a vertical grip that allows you to use three batteries at one time.
If you find the grip and camera with two batteries too heavy, you can remove the battery in the camera and just run with the two batteries in the grip and everything works fine.
You can use the vertical grip as a dual battery charger when you don’t have it equipped on the camera and it can charge two batteries in 2 hours with the AC wall adapter.
The Fujifilim X-T2 battery grip will not work on the X-T3.
Fujifilm BC-W126s Battery Charger
For the Fujifilm X-T3 and the NP-W126S batteries, there is a brand new charger – the BC-W126s.
This new charger comes with a wall plug adapter built-in so that you can plug the charger directly into the wall. No more cable.
If you like the cable and need another battery charger, the old BC-W126 charger still works fine.
Recommended Memory Cards
1) Sandisk Extreme Pro UHS-II
Sandisk Extreme Pro is the best card for Fujifilm cameras. They have no issues and I’ve never heard of any lockups with this card.
https://www.amazon.com/SanDisk-64GB...if-20&linkId=359c773aeddc2c2dfcd087a6b6b7e10e
2) Sony G UHS-II
Believe it or not, Sony actually puts out really nice memory cards and they work great in Fujifilm cameras.
https://www.amazon.com/Sony-SF-G64-...if-20&linkId=f4c27298f1ff2e2bf8ee71c082b4d3af
Soft Shutters
The Lensmate Soft Shutters are the best and this is what I use on all my Fujifilm cameras. These have a rubber washer that when tightened helps keep the shutter from vibrating loose.
Nice Fujifilm X-T3 Leather Half Case
I’m sure Kaza will give us something really cool. Provide the below links for your reference.
Kaza Leather Carmera Half Case
https://kaza-deluxe.com/shop/product/fujifilm-x-t3-series/
Gariz Genuine Leather Carnera Half Case
https://www.amazon.com/Gariz-BL-XT2...+xt3&qid=1556086393&s=gateway&sr=8-3-fkmrnull
2) Sony G UHS-II
Soft Shutters
