Muslin, paper or vinyl backdrops??
Raptor Mike
Mike
I've been looking at backdrops and see you can get them in paper, muslin or vinyl. I was wondering which is best. I would've though paper would rip or crease easily, especially when stood on. Muslin would crease easily. Vinyl is heavy. So which ones do you have and how do they work out for you?
Which is best probably depends on what you want to do with it. White vinyl is the most efficient at being white, and black muslin is most efficient at being black. Muslin may be the easiest to travel w/ and set-up. Vinyl is durable but expensive/heavy, and it does wear out/scuff. I use paper... white and black. I think if I did more work using backdrops in a studio I would use vinyl.
I have worked with someone who uses a sort of stretch fabric (I think Lastolite do something similar) and it was pretty good - it was easy to wash, could be just stuffed into a bag and any wrinkles could be tensioned out by the floor/backdrop stand/gaffer tape to pull the fabric slightly taut if required. Any excess width or length could just be bunched up at one end out of the way.
There is no "best" each have there good & bad points & it depends on the shoot.
Paper - cheapest per square metre, widest range of colours, should be treated as a "consumable", give a flat clean colour. If used on location you need a hard smooth floor to stopp creasing & ladies heels going through or a sheet of hardboard underneath.
Vinyl - generally the moste expensive, limited range of colours, have a sheen to the surface, relatively hard wearing compared to paper, popular with event photographers where you have a high throughput of trafffic over the background, if they get dirty a bit of kitchen cleaner normally gets the marks off.
Muslins/cloth have a texture to them, cost wise in the middle, last a while, ( still use a few Lastolite cloths that are 20+ years old), if thin can be backlit & used in front of other backgrounds.
Then there are a whole range of theatrical cloths available from companies like J D McDougall. (their Black moulton is great if you want a black black )
Plus there is also the storage & portability aspect, a 9ft vinyl is fairly heavy & need a good solid support system, papr rolls lighter however if left permanently on support systems that don't have a central core or store badly can bow. "Fixed" widths ( papr rolls can be timmed using a wood saw eg if you want an 8ft roll, cut a foot off a 9ft one)
Cloths are easily stored, can be fixed in a vriety of ways & useful wher space is limited.
Most studios have a mix of all three.
If I could only own one background it would be a mid tone grey paper/wall & then assuming I had the space light it with gels see here
Thanks for you thoughts guys, much apriciated. The biggest problem for now is that where I want to set up a background a home is a carpeted floor. But I could use a big bit not board. I like the idea of the gels. Thanks again all :thumbs:
Thanks for you thoughts guys, much apriciated. The biggest problem for now is that where I want to set up a background a home is a carpeted floor. But I could use a big bit not board. I like the idea of the gels. Thanks again all (y)
Re board to go over carpet - get an 8' x 4' sheet og hardboard from B&Q, get them to cut it into 4 x 4' x 2' then Gaffer tape the pieces togetheer in situ, this also works out cheaper than buying pre cut 4' x 2's
I've got a big bit in the shed I bought that I never got around to using. Thanks for the gaffer tape tip (y)
Vinyl white for clean cut images as is the trend at the mo... Easy to clean and hard wearing.
I go for paper on coloured bgs...
and we use Muslin 6mx3m for large groups upto 30 people. Chroma key always use material. Vinyl is no good . You need a matt service for good Chromakey.
Thanks for that advice :)
I just use paper at home and have found it quite durable as the kids don't go on it in shoes. My studio area has a hard floor though.
