I do a lot of prints for clients, mostly small ones that I print on A4 sheets the majority of the time.
The issue is that I can never get a consistent cut on the prints. I want all of them to be identical but if you have three 6x4 prints on one page and you cut them manually you will end up with a pile of prints that are all different sizes with some sticking out.
I already have a very big expensive paper cutter but it's still not accurate enough. I wanted to know if there's something better out there like an electronic cutter of some sort.
I can't order the correct size papers for all sizes as there's over 50 and the printers don't allow most of them.
