Jannyfox
- Jan
- No
I've started using a monopod for wildlife photography (mainly birds) as I find it more versatile (and lighter) than the beanbags I used to drag around, however especially in a hide, when I can extend it to the ground and lock it in position with my knees, it needs a head. I want something with friction adjustment so it doesn't flop around, but obviously neither do I want to use it locked up. That would seem to rule out ball heads unless there's one that has friction adjustment that would be suitable. In every other way a ball head would be ideal as it moves all ways, is small and fairly light (weight is an issue for me). The other alternative seems to be a lighter weight video head, but can they be used without the arm attached? What I don't want is a gimbal, as they're too big, too heavy and too expensive. I just want the head attached to the lens foot while I hold and move the camera and lens much like I was handholding it, ie not swinging it around using an arm like you would a spotting scope or camcorder. Hope that makes sense. Anyone use a head on a monopod (or tripod) for birds and can offer any suggestions?
Monopod is a Manfrotto 290. Load to be carried is a Sigma 150-600mm C/Canon 800D, so about 2.5kg.
