Monitor Calibration
Bristolian
Steve
Hi there knowledgeable folks :)
I have dual monitor set-up and have been using a Pantone Huey calibrator for quite a few years - it has finally died :(
The Huey only ever calibrated one monitor and I adjusted the other to suite but would now like to buy soimething that can calibrate both monitors individually. What do you learned people recommend/use/suggest?
My PC is home grown with an ASUS mobo, AMD Athlon 64 X2 3GHz cpu, 8GB RAM, ATI Radeon HD4600 series graphics card with 1GB memory and dual DVI-D outputs. I'm running W10 Pro (64 bit) and use both Lightroom and Photoshop CC for editing. I have no problems with the performance of the PC even if it is a hand me down from Mr Babbage :)
PS: I don't particularly want to have to take out a second mortgage for this :)
Regards
Steve G
Steve,
Have a look at the i1 display pro. I had the spyder 3 pro but prefer the i1 display.
the "pro" versions of the spyder do multiple displays (assuming your gpu can load multiple profiles). should be reasonably cheap to pick up a 2nd hand spyder 3 pro, works on Windows 10 even though it does not list it.
