dubcat
- Amir
Hi - I thought I had my head around this but clearly i don't.
Let's say I have two flashes which I control via e-TTL (i use the canon st-e2 transmitter). These will be my key light and my rim light or hair light. I then have two flashes which I manually set, are only used for lighting the background, and can not communicate with the st-e2 as they are not ettl.
Q1) Can i trigger the front two flashes via the st-e2 and then use the optical trigger for the background flashes?
Q2) If I WAS using rf-602 could i just have one transmitter, one receiver on the key, and then set all other flashes to optically trigger?
Thanks.
Dub
Thanks.
Dub
That thing is flippin clever with Hypersync and enhanced HSS that even Canon can't match.
