Minolta 28mm F/2.8 ... Lens Servicing, Help!!
Smurf.
Hi,
I have the above lens and have some fungus, so I have stripped down the top part of the lens and removed the optics ... how do I split the optic to remove the fungus?
Help would really be appreciated.
Do you mean you've removed a group of elements and you need to clean the fungus inbetween? Not sure about this lens, but these are often glued and therefore not cleanable.
Thank you both, I have disassembled and removed the group of elements. Managed to split them in the end! :) The lacquer was set on but after a good soak in Toulene it softened enough to separate them.
One nicely serviced 28mm ready for use now :)
For anyone else interested; It is the front element as seen here:
As I say; now sorted :)
