Frosty11
- Alan
As my learning experience hits a new curve I'm now faced with light metering for those amazing landscape shots. I've learnt the use of a polariser, ND and ND grads, but I'm new to metering in manual.
As I understand it I take a reading from the sky / bright area and take a note of the exposure. I do the same, but this time the foreground / dark area. Again I take a note of the exposure. Now here's where my mind losses it a bit.
I've read that I should use the appropriate filter to within 1 stop of the final reading, but what do I do if the reading is say 7 stops above the lowest exposure reading? Do I bring it down using -EV by as much as possible or do I use something like the Big Stopper? Also if it is within 1 stop is it 1 stop above or 1 stop below i.e if the sky is 3 stops brighter than the ground, should I add a 0.6 ND (2 stop) grad filter or two 0.6ND (4 stop)?
Hope I haven't confused you
