sk66
- Steven
Ok, this might seem like an odd question... but I was testing the AD200 and a homemade modifier (fresnel spot) and I wanted to start with a base knowledge of "how much light can the AD200 add?" The idea is that if I know the amount of light the strobe can add at 10ft unmodified I can quickly SWAG distance/power settings to get the results I want.
But now I'm not sure I'm doing it right technically. I started with a base black frame exposure w/o flash and where the flash at minimum power (1/128) was visible, and at 1/2 power the white wall began to clip.
So, is that 7 stops to clipping (8 stops total)? I don't thinks so as that's really just the adjustment range of the flash. Or maybe that's just coincidence... using the same method I got approx. 9 stops for the AD360 w/ standard reflector (the AD200 was w/ the fresnel head and I think my "black frame' might not have been quite dark enough).
Is it the 10 (12) stops of the zone system? I don't think so... I think the zone system is more "theoretical."
I was using the D810, so is that 14stops at 1/2 power, the DR of the sensor? Maybe, but how would that relate/convert to other cameras?
Or is there some other relevant measure/standard?
BTW, the fresnel spot was a flop, I actually lost .3 stop of light...
