I find MF with AF lenses a right PITA! Partly because bodies designed for AF tend to have plain ground screens without any focus aids like split or micro prisms but also because AF lenses have a much shorter throw from close to infinity (presumably to speed up AF and reduce power usage), so a tiny tweak can overshoot what you were aiming for. Even with macro, although I usually switch to MF rather than AF, I set the magnification I'm after (or a vague focus distance) using the focus/magnification scale then move myself back and forth (or the camera on its tripod if tripod mounted) rather than rely on AF or MF for the minute adjustments needed.
