Manual Flash
The latter. Dropping the power by a half lowers the light by one stop. Its really just the same as +/- flash compensation
either invest in a light meter or use the suck-it-and-see method.
Easiest way is to start at say 1/4 power, fire off a shot and then adjust the power up or down as needed.
Cheer guys.
Looks like the suck-it-and-see method then. May add a light meter to the Christmas list, any recommendations that won't have the missus saying "I'M NOT BUYING YOU THAT!" ? :D
No :lol: A Sekonic 308s is about the cheapest decent one at £125 new
ok, so at full power if the flash has a GN of 58 (ft or m?) you can calculate what aperture to use by using the equation fstop = GN/distance
for example if the subject is 15ft away you would do 58/15 = 3.87 ~ f/4
this is a very simplified version, as you have to take into account the film speed and the GN changes as you reduce the power of the flash - 1/2 power would not just be 58/2 though.
your best bet is to just google 'guide number equations' as I'm sure there will be a better more comprehensive explanation out there. I used to use them all the time, but have gotten lazy since I bought my meter (sekonic L358) about a year ago.
I've got a L-358 as my light meter. Very very good buy that was!!! Get one of those ;)
As for manual power of your flashes I just do it depending on what the natural lighting is like and if your wanting a more natural flash look to match the ambient or if your wanting to just have the light from the flashes.
Bright sunny days - 1/1 or 1/2
Overcast - 1/2 or 1/4 (depending on the effect and lighting I'm going for)
Night - 1/2 or 1/4
Then change the light spread as well, so if you want a more direct light on your subject or a wide light spread.
Well thats what I do in my skateboarding shots anyway. It's just a matter of trying and seeing really
