major computer problems
whitewash
Fishy Fingers
over the past few days my laptop has pretty much ground to a halt, everything it does is slow and laborious, usually its seriously quick. nothing i can do really makes it any quicker, its actually impossible to listen to music anymore as sound slows down and everything sounds robotic as its slowed down. it now takes over 5 minutes to load up on a restart
ive not installed anything prior to the problem, i was getting low on disk space prior to the problem occuring but thats been rectified and appears to have no effect on it as the harddrives have been cleared to have over 45% free space each and have been defragmented. i have also done complete scans with AVG antivirus, spybot S+D and adaware and nothing bar a few tracking cookies was found.
the only think i have noted is that thier are now alot of processes running in the background, non of which i can find to cause any improvement when closed. CPU useage appears to be pretty much maxed out but the only thing thats using CPU for the majority of time in the processes tab is "system idle"
heres a list of them all-
Image name........username.......memusage
ZCfgSvc.exe jay 7,316k
hkcmd.exe jay 2,346k
igfxpers.exe jay 2,456k
SynTPLpr.exe jay 2,320k
Explorer.EXE jay 17,212k
1XConfig.exe jay 4,744k
SynTPEnh.exe jay 4,072k
taskmgr.exe jay 4,328k
RTHDCPL.EXE jay 22,424k
epm-dm.exe jay 2,912k
QtZgAcer.exe jay 6,376k
Monitor.exe jay 6,096k
avgcc.exe jay 424k
PDVDserv.exe jay 2,852k
iFrmewrk.exe jay 7,404k
EOUWiz.exe jay 6,388k
jusched.exe jay 2,060k
iTuneshelper.exe jay 3,592k
MsnMsgr.Exe jay 3,508k
msmsgs.exe jay 1,884k
SVCHOST.EXE Local Service 4,200k
ALG.exe Local Service 3,412k
SVCHOST.EXE Network Service 4,128k
SVCHOST.EXE Network Service 2,840k
System idle Process System 28k
System System 236k
ADCDLicSvc.exe System 1,088k
avgamsvr.exe System 772k
SMSS.exe System 396k
avgupsvc.exe system 616k
CSRSS.exe System 4,200k
WINLOGON.exe System 3,542k
SERVICES.EXE System 3,376k
LSASS.exe System 1,060k
SVCHOST.EXE System 4,748k
LSSrvc.exe System 1,360k
SVCHOST.EXE System 18,624k
EvtENG.exe System 7,272k
S24EvMon.exe System 4,488k
OProtSvc.exe System 3,700k
RegSrvc.exe System 2,340k
SVCHOST.EXE System 3,968k
SPOOLSV.exe System 5,148k
AnbmServ.exe System 5,916k
iPodService.exe System 3,624k
dunno if thats any help but im completely lost on this, i really dont fancy a complete reinstall after only 6months but if thats what it takes, s***ting computers driving me up the wall!
if anyone has any help that would be fantastic
jamie
This site will help you to find out what all that stuff is for.
You might also go to Start>>Run, and type "msconfig". Click the Startup tab, and that will show you everything that gets launched automagically when you switch on your PC.
You can also open Task Manager, go to Processes and check out what is hogging all your CPU time (under the CPU column - percentages).
I've had a look around and msmsgs.exe could be the cause of your problem as it indicates possible virus infection which causes, among other things, system slowdown.
More here.
That will be the one.
But I see that you have an Acer lappy with all the pre-installed gumpf that comes with it. If it is anything like the Sony lappy I recently sold, I would strongly advise de-installing all bundled bloat that came with the machine. This action had a huge effect on my Sony.
Looks like a tonne of viruses, spyware or trojans there. Check your anti-virus is up-to-date. Install some Spyware killer too.
More here.
msmsgs = "it's the Messenger service that XP uses to alert Microsoft of updates and such, different from the MSN Messenger." apparently - though it seems it can be used by some viruses, wouldnt say it is deffinatly the problem. If you have AV and Firewall they should pick up on that doing anything odd.
you can remove msmsgs from add/remove programs and going into the add/remove windows components section, scroll down to windows messenger and remove it ! It wont affect MSN Messenger, as they are seperate entities.
It is one of the routes nasties get onto your computer and is the first thing i remove when i get new computers !
Not certain its the cause of your slowdown, what AV program are you using ?
You could try this - http://www.pctools.com/aoss/?ref=news_pctr
It lets you create a bootable CD which runs a virus/spyware check without using the PC's own OS, so in theory it should recognise hidden nasties which are difficult to remove when Windows is running. ;)
go to run then type services.msc and scroll down and disable windows messenger. kind of asking for trouble running it.
Ideally you only need around 18 services running. Anything above that and your wasting system recources.
Below is a highlighted list of gumpf/virus'/trojans/spyware What you really need to do is back you files up, format and reinstall nothing but windows basic and PC Tools Spyware Doctor (buy it, it is very very good)
avgcc.exe jay 424k
System System 236k
Off the top of my head thats all s***e, get rid/disable using services.msc asap. or like i said above, format and reinstall. If you are anywhere near felixstowe Ill help you do it, got many years experience fixing/building pc's.
dont be using your credit cards on that laptop until its sorted.
King.
EDIT: UNINSTALL AVG FREE ANTI VIRUS SOFTWARE IF YOU HAVE WHICH I THINK YOU DO.
avgcc.exe jay 424k
System System 236k
I couldn't be bothered to check up on your list, but I know for a fact that at least half a dozen of the ones you're telling him to remove are not spyware/trojans at all. For example, shared internet connections might stop working if you get rid of ALG.EXE. Its part of windows and completely harmless.
Why are you telling him to remove AVG?
download lavasoft adware, spybot 1.4 and avg antispyware free and scan with them and that should remove the problems
I couldn't be bothered to check up on your list, but I know for a fact that at least half a dozen of the ones you're telling him to remove are not spyware/trojans*1 at all. For example, shared internet connections might stop working if you get rid of ALG.EXE. Its part of windows and completely harmless.
*1 No buts its gumpf, services that dont need to be ran in order to achieve something.
AVG is an absolute brute. It has casued more problems for me in the past than what its worth.
You can actually run a windows system on very little processes. Ill find the link regarding which services can be disabled and you'll be surprised how many can. When I was using PC's (moved to mac becasue I got fed up of having to overhaul the system every 3 months due to the awfully bad way windows falls apart) I ran as littel as 12 processes sometimes. Upon overhauling there were a merge 8 - 10 running. the amount of crap that windows runs in the background is amazing. You really dont need that many.
I use SpyBot regularly ... seems to keep me clear of problems ... over and above normal AV of course ... ;)
:p
never had a problem with AVG, far less of a pain than nortons or macafee!
Me either. It makes me laugh when people complain that AVG finds more viruses than Norton does. Surely that's a good thing? :thinking:
i upgraded to the pro version of AVG, not really much different from the free one though...
ive been using avg for years but recently lots of rubbish and viruses coming thru. I have now bought PrevX1 for £14 PER YEAR. is great...finds stuff avg doesnt find... viruses (or is that virii!) spyware etc etc.
How about a screenie of your Task manager?
Which process is using all the CPU power.
If system idle is the only process maxed out then the system has no load from anything that shows there.
How old is the laptop? Sounds like some kind of hardware conflict/fault to me. I'd try booting in safe mode and also boot from a CD to see if a driver is making it slow due to problem hardware. No badly seated connections on hard drive(s) CD module...memory...anything?
ive got the running processes down to 25 and it seems a bit better, so im gonna keep stripping it down, found a few bits with AVGspyware.
my laptops is 6 months old (remember the thread anyone!),
i appear to have lost the task manager as well now, when it comes up it shows only the running processes and the end process button, no tabs or box frame or cpu usage figure
any help would be great
still not having much joy but im trying to disable a few things in services.msc to see if that helps
sound is still useless though as is watching videos and its still slow
Just under the box where it says "Show processes from all users".....double click that grey area..that'll get you your title bar back :)
ive found the backup/recovery program for my computer but ive deleted the program that it uses to burn the DVD, so im trying to reinstall it now. hope it works.
ill keep you all upto date, this is really annoying me now!
good luck, let us know how you get on.
sorted
i thought it might be a good idea to read the ****ing manual :rules:. at which point i realised i didnt need to reburn an image to cd, clicked a few buttons and badaboombadabing my laptop now thinks its minty colgate fresh and runs lovely and peachy.
thanks for your help guys xxxx
:gag: <me
sorted
:gag: <me
LOL well at least it working ok now ! :)
sweet mate, glad you got it running :exit: :)
well i thought id fixed it, ran all windows updates, installed firefox and itunes and updated media player, installed girlfriends creative zen onto computer as well, all was running sweet using AVG and zone alarm to protect. i then turned the computer off, and came back to it 5 days later (been away with work) only to find its doing the exact same thing as before only not to the same degree.
what should i do? short of throwing it out of the window im a tad lost
