- Yvonne, pronounced Eve...
Morning all
I have a feeling I know the answer to this, but just wanted to check here in case anyone has any clever ideas that will save me several hours.
Yesterday my mid-2011 iMac, running mavericks, suddenly slowed to an absolute crawl. No apparent reason for this, I had several programs open, usual sort of stuff, LR, PSCS, Firefox [with just this forum open in it], MacMail and Tweetdeck. So, after some time wasting pain of closing stuff down, lots and lots of spinning beachball, I managed to shut it down and reboot. Still the same. Checked activity monitor, which took forever to open, but nothing showing there as tying up loads of resourses. Checked disc utility, all seemed well there.
So, rebooted again but this time with only my TM disc plugged in, no other external HD's and holding Cmd-R to get to the separate disc utility. Ran a verify disc and it said the OS disc needed backing up and formating/new installation. Tried repair disc, but it said it couldn't be repaired.
So, I opted to restore from TM and gnashing my teeth over the time wasted because I have a lot of work on, settled back to wait. Eventually it all sorted itself out and the machine is now back up and running and much quicker than its been for weeks. Disc utility from the backup system reports that the disc is fine.
However, here is my problem, the inbuilt back up is the only way I can access Disc Utility, in fact, the only item from the Utilities folder that works is the Activity monitor, nothing else. No Console, no nothing. I did try entering TM and over writing that folder, but of course it won't let me because it OSX uses it.
So, I have a horrible feeling that the only way I can sort this is by doing a completely clean install and of course all the associated reinstallation of software [finding all those sodding licence keys again, etc] I am probably going to do this anyway, but would prefer to wait until I have got rid of a load of work. So, in the meantime, anyone got any bright ideas that might sort it out? Obviously after this problem I would like to be able to quickly check the discs regularly in case of any impending problems, without having to constantly reboot to do so?
if someone tells the syntax to run checks, happy to do them, but no idea where to start myself these days.
