I am having lines appear on my prints please see below image for examples (this is 3 different prints). I can get the occasional good print, but 2/3 are bad.
The printer is a Canon iP8750 around 6 months old.
I have run a few cleaning cycles and deep clean cycles, the test print before running the cycles only has a few faint lines, usually on magenta. After cleaning, the lines appear fine on the test.
I'm presuming this is clogged nozzles that the printer can't resolve itself, do you agree?
If so, should I try using one of the liquid uncloggers with a syringe or would you recommend another route of action?
