Lightroom Ctrl Z problem
theotherleft
Hi guys,
I'm hoping someone can help....
Recently after making a set of changes across various images in LR (1.4) I've then wanted to correct a step and so used Ctrl Z. However the impact has been to undo every change that I have made since I opened LR, whether they are edits or ratings!
I'm sure it didn't use to do this, nor should it. I can't figure out any general settings that may be driving this.
You can imagine this is hugely frustrating too, so help would be appreciated.
thanks
Dean
Click on the previous step in the History column on the left. This will undo your last change. Go down further if you want.
