Lightroom control devices
PeteNaples
Pete
I get increasingly frustrated clicking through Lightroom menus.
Has anyone amongst used any of the various control devices available, and if so, what are your thoughts?
Tourbox, Loupedeck+, Behringer Touch Mini etc.
Learn the shortcut keys. How often do you really need to use the menus?
I’ve tried a device similar to the loupe deck but spent far too long looking for the correct button to press as they are often nested. Too much of a pain in the backside.
Surely though, one configures things like exposure, contrast, blacks, whites etc on rotary knobs?
So the basics are at your fingertips.
I looked up the kyboard shortcuts, there are a hell of a lot!
I also looked up LR keyboards.
Another rabiit-hole to look into.
not me
You need to select the few that will make the most difference to your workflow,and then add new ones into memory over time
I found that using the develop panel in solo mode and then using (on a Mac) Cmd+O, Cmd+1 etc to open individual tools to be a massive time saver.
However, I much prefer the way Capture One does this, where for example, you can hold the "Q" key down and then use the arrow keys (or a pen or finger on a tablet) to adjust exposure. Nearly all adjustments; exposure, saturation shadows etc have an assigned key and I find this a really quick and easy way of working, without ever going near the tools panel (the adjustment settings pop up when you make any changes).
I am unaware of anyway of doing this in Lightroom, and if I routinely used LR, I would probably do what you are doing, and look for a control panel with knobs or sliders. I am aware of people who used to to use an external control box, who stopped using them after C1 introduced these "speed edit" keys.
But even learning half a dozen keyboard shortcuts can make a big difference, you just need to work out which ones to learn first. Once you get into keyboard shortcuts they tend to become obvious. ie you realise which actions are the most tedious and annoying, and make the effort to find or create a keyboard shortcut.
I don't find that there are any "standard" or common edits that I tend to apply to most images... other than detail adjustments (sharpening/NR). And I just don't find using the sliders to be particularly slow/cumbersome (used with touchpad). But I have never been as sloppy/hurried as any of the example edits I've seen done using a controller interface.
For a good while I used Midi2LR and tried a few different controllers; my favorite was the Midi Fighter Twister. But in the end I just found it to be another interface/encumbrance... much like my graphics tablet; useful at times, but mostly not worth the hassle. Maybe if I had a dedicated workstation just for photo editing I would feel a bit different about it.
No need, just hover over a slider don't even need to click on it and just use up or down keyboard keys, or a mouse / track pad scroll wheel. It's very quick to begin with
Furthermore you may also find you start with most images of a certain type using very similar settings. Just import by applying a simple preset like this - already saves a couple of min per image and just fine tune as required
