Not sure if i can explain this right but after changing my pics in develop module i export into CS5 which comes up in camera raw but no changes appear what am i doing wrong
When you export, what settings are you using? In export you have options to edit original or edit with Lightroom Settings. Make sure you use the right settings.
The ACR module in CS5 isn't compatible with LR4. LR4 uses a different process engine. You could try downloading ACR 6.7 which ådobe claim should have the same process engine as LR4 but it didn't work for me
When you export you should get a dialogue box offering you the option to let Lightroom process the image. Opt for this. Simply clicking straight into CS5 will not have the LR4 develop actions applied and will simply open into ACR for CS5.
You could download the trial of CS6 as this has the same develop module as LR4 and will apply the corrections. However this is only a public Beta which will expirewhen CS6 is oficialy launched
