Light triggers ??
oblivion
Richard
Ok so here is the setup.
5d Mark ii using speedlight 430 exiii RT.
I have Elinchrom D-Lite 4's for indoor use.
Currently use a small trigger that came with my d-lites to make them flash which fits onto my hotshoe.
I want the ability to use a trigger to make my 430 ex fire off camera for outdoor use.
I also want the ability to use a trigger to make the d-lites work when I fire my speedlight attached to the camera body for indoor use.
My question is (never having played with triggers) is what trigger set do I purchase ??
I'm not after the most expensive all singing and dancing set, just a set that will do the job without hesitation. Can someone point me in the right direction, provide a link and give a reason/explanation about the different models and pros and cons.
Thanks muchly in advance
The rf603's are cheap and cheerful, but you may as well expand into the system you've already paid a premium for IMHO.
The YNE3rt will control your 430 off camera as well as it you can on camera in both ETTL and Manual modes, then you just need some relatively inexpensive YNe3 rx units or just use the optical slave in the Dlites.
