psybear
- Brian
- No
I was doing some long exposures at the weekend and some of my images suffered from what appears to a light bleed issue (see pic).
Set-up was Nikon D800, 24-70mm lens, Lee 15 stop and 0.9 soft grad filters, exposure time was 70 seconds at f/9. Conditions were overcast with no direct sunlight. The rear eyepiece cover was closed.
When I noticed the flare in an exposure I used black low-tack tape to wrap around the filters and filter holder (something I don't normally have to do in overcast conditions). The problem persisted. I then removed the filter holder and replaced it to check it was secure, no difference. I then turned it upside down (reversing the 0.9 grad), still no difference. I then altered tripod position and composition slightly - and the issue disappeared!
(If there is a more appropriate forum that this one, please advise!).
Thanks.
Anyone got any ideas? This happened to me once previously in a similar set-up,
albeit on a brighter day - I had actually forgotten all about it until it happened again.
Thanks.
Filter_Lens_Fault_D810-1212
