lens please help
Student Mike
Mike
hi guys
im trying to pick a new lens for my camera, but im very confused. there are AF/EF/EF-s/and IS lenses...... apparently the all fit and work with my camera, but i havent the first clue as per which is the best? or best value for money?
also i have no idea what the f/number bit means (i.e. f/4.5-5.8 etc). someone said its the amout of light it needs?? or amount of light it lets in?? is it best to have a big f/number or a small one??
Hi Mike I'll answer the bits i know and let some else cover the rest.
AF= autofocus, meaning when you half press the shutter button the camera will try to lock focus on the subject over the focus point(s) you have selected.
IS= Image Stabilisation, typically in two modes, one counteracts movement in the horizontal plane and one counteracts movement in the vertical plane. By movement i mean camera shake. In theory IS means that you can shoot a subject using a lower shutter speed than with a none IS lens.
F/ Stop. this is a ratio of the area of the opening of the lens (apperture) divided by the focal length.
A) so you could have a lens with a focal length of 280mm and an area of 100mm Sq for your apperture this would give you an F-Stop of f/2.8
B) you might have another lens of 280mm focal length but the area of the opening is only 50mm Sq, this would mean that half the amount of light is let into the lens and would give you an F-Stop of f/5.6
so lens A is one stop faster than lens B, this difference is crucial for photographing subjects in low light.
Ideally you want a lens with 1) a constant apperture (pricey for a zoom lens) 2) an apperture that is as wide as possible
typically the lens that are faster will be more expensive than other lens of the same focal length as an example the Canon 400mm f/2.8 which is a standard lens for football photography now retails at over £6,000. the 400mm f/5.6 retails at less than a quarter of that price.
I hope some of this makes sense, but i've just got up and my brain ain't awake fully.
For buying lens, first i would think carefully about the areas you want to photograph. Sports and wildlife typically mean lens with a long focal length and they get pricey VERY quickly. Landscapes usually require shorter lens at a guess anything from 35mm down and portrait probably 50mm to 200mm.
You should buy the best you can afford and if you invest in high quality well built glass, it will last you years (providing you look after it)
Andy
thanks for the advice. so the smaller the f number the better really?
yes, the smaller the f number the better as it allows more light and gives better image quality under low light conditions
ok. thanks. i primarily use my camera for motorsport shots, so was looking for a 5-600mm lens. one i looked at had a F/8-16 so ill be leaving that alone i think....
sounds like a mirror lens, i wouldn't touch it at all, and for motor sports you wont want f/8-16
a better bet would be somethink like the canon 100-400 or the 70-200. the 70-200 comes as f/4 or f/2.8 and with or without IS but they are all around the £1000+ mark
Im not an expert on Motorsports but there are plenty on here who are and can advice better on what lens to buy.
I really wouldn't buy the lens you suggest though. Any thing with such a long range of focal length is going to be pretty poor......................
Give us a budget Mike. Chances are that will thin down the options so you won't have to worry too much about any other numbers ;)
