Phobic
I'm a simple kind of a guy, I know what I want and I don't think I'm asking for anything to unrealistic.
I would like to use an ND Grad Filter with a polariser and a lens hood for landscape photography and not have any vignetting!
My first stupid mistake was to try doing this on a full frame camera with a 24-105mm Lens. The only way to avoid vignetting on this lens at 24mm is to limit myself to a single filter slot and ditch the hood.
There is a 105mm ring adaptor which I assume will plug into the 105mm polariser (though I note that it's not wide angle), if I invest another £53 +p&p will this let me use the Hood as well on a 24mm lens on a FF body?
Has anyone else used this set up?
I have no problems with my 35mm prime but as a landscape tog I would like to buy the 24mm mark II prime, and use filters with it!
<rant mode>
This should have been an easy thing to do, not bloody likely without vignetting! I've spent slightly more than the national debt on Lee filter equipment at Warehouse and I still can't use these 3 together.
Lee Glass Circular 105mm Polariser £214.99
Lee Coral Graduated 4 Resin Filter Hard £40.99
Lee 0.9ND Soft Neutral Density Graduated Resin Filter £59.99
Lee 0.6ND Soft Neutral Density Graduated Resin Filter £56.99
Lee Wide Angle Adaptor Ring - 72mm £35.99
Lee Wide Angle Adaptor Ring - 77mm £38.99
Lee Lens Cap Pack of 3 £5.99
Lee Wide Angle Hood with Single Filter Slot £164.99
Lee 105mm Front Holder Ring £31.99
Lee Foundation Kit £52.99
Delivery: £4.99
Total: £708.89
£700 for VIGNETTING!
:bang: :bang: :bang:
</rant mode>
Help me obe1 you're my last hope
Phobic
<rant mode>
Delivery: £4.99
Total: £708.89
</rant mode>
Phobic
