realspeed
- Bazza
- No
Yes the front porch had a leak and a tiler has done a temp fix and coming back to fit new felt etc
So to find the where the leak was the plywood was so rotter in fell apart at a touch
so next was to strip it all away and fit battens to screw planks into on the sides
then start the repair using these
got this far at the moment. the front bit was a sod to fit around everything and add the air vents
Rain stops work but made a template for one side at the back. Just got to do other side then cut plank to the templates
When last bit fits it all comes down to countersink the holes and weather proof the hidden side. Then the final finishing either quadrants or mastic before adding colour which has to be brown
