LCD Cal - Help?
wcavanagh
Right done a lot of reading, and I’m still confused. I have brought 2 nice new 22" Screens, that will be used in a dual screen setup on Vista 64bit. Now I would like to cal them, as best I can. I don’t want to spend a fortune no more than £100 I have read of several devices. Just wanted some feedback on what you guys use and your experience?
I have a Huey Pro and a Dell 2407, the calibrated colours are very similar to the un calibrated colours. I have used this also with a samsung syncmaster 151s which is a much older monitor. Once calibated the syncmaster matches the Dell so I can see that they are both calibrated to the same levels. If you look at the two apart and uncalibrated then the difference is vast.
I have also used this device to calibrate the laptops and again they match the Dell.
Make sure that which ever device you buy allows dual monitor use as some do not.
The Huey pro is about £90 and a lot cheaper from the US via ebay. I saw someone in Canada selling some for £57 not too long ago!
I was looking at the Huey pro seems to do everything I need, will have a look over the bay :)
Well that ws easy, ordered the Huey Pro from US Ebay for £64.17 delivered with insurance. Thank you for the heads up, Bargain.
