what exactly are you trying to achieve and your location would help![]()
it will be over laminated with a Matt laminate, they are made by companys like Drytac, hotpress, sealion, zenith. Its a plastic laminate whixh can be applied hot or cold (there are diffrent products for each typr of application.) if doing a hot press version you will require a vaccum press and the cold version will require a cold pressure roller laminator.
I use a cold pressure laminator made by Jet Mounter.
Ask at a local framing shop they mybe able to do it for you.
