StuartPearson
- Stuart
I tried taking what I expected was a simple photo, a multi flash image capturing a party popper being set off, however no matter what settings I used I could only ever generate a single flash. Both the YN560 flashes (v3 & v4) output a multi flash at the set frequency when using the test button but no joy when either directly connected to the hotshoe on my Panasonic G5 or wirelessly connected to a YN560 TX unit. I do have a workaround where I can repeatedly trigger either flash via their PC port (relay contacts shorting the input) but would really like the flash to work as designed.
Any ideas why it doesn't work, is there something proprietary on the Panasonic hotshoe signalling that only works with their own flashes for this level of operation? All other elements of the flashes work whether there is a direct connection or supplied over the wireless trigger.
