ronb
I am off on holiday to Dubai very soon, should I use a slightler higher ISO whilst I am there on account of the brilliant sunshine leaving the camera on Auto, or should i leave the ISO at 50 and shoot manually??
The brighter the light the lower the ISO.
Unless you want to add noise/digital grian to your images
So I should leave it at 50 then??
Yes..as Matt has said the lower the iso the less noise you will have in your pictures. As you are going to Dubai which would suggest that the lighting will be bright and sunny this should not stop you taking any pictures ar reasonable shutter speeds.
Basically the only times you should increase the ISO is when the camera sets the shutter speed to below what you require due to low light, or if you are trying to create a noisy photography on purpose.
Thanks for the info, I will leave it at 50 and watch the shutter and AF settings.
