Hi all,
I'm going to shoot a friend and her 16 month old son this weekend and am looking for any setup tips/advice as I think we will end up shooting indoors at her house. I have limited experience with indoor/flash photography and kit so would be grateful for any constructive advice. Keeping the little guy occupied and/or concentrating (yes, got toys/treats etc) means I'll need to try and work fast.
I have a gripped 40d and planning to shoot in aperture priority shooting flash on ettl, will take my nifty fifty and tamron 18-50 2.8 (will probably use this most). Lighting wise I have a 430exII, stofen difuser, off camera flash cable, large tripod and a small 23x23(cm!!) folding softbox/difuser thing and an 80cm reflector set.
I was thinking of mounting the flash with the difuser high up on the tripod, the cable will reach a few metres which indoors should be plenty based on rooms sizes there. I was playing around with this setup at home and shadows were still a lot softer when bouncing, should I be bouncing off ceiling or lighting direct? If shadows are harsh should I be adjusting flash exposure down a bit? Should I have the wide angle flip down or stofen on the speedlite inside the softbox/difuser? - will this help or make a noticeable difference?
I also noticed a more natural/softer light temp when setting white balance from auto to flash (previously thought the camera would figure this out from the auto setting but the difference was huge)
Planned to use the gold reflector in front of subject (obviously out of shot) to try and minimise shadow under chin etc and add a bit of warmth.
I am going to try for plain backgrounds and use big apertures and try and get them away from walls to minimise shadows and blur things out in the background.
Am I on the right track or should I be doing things differently? Also any tips for directing/composition/poses appreciated!!
thanks if you've read this far..
Andrew.
Andrew.
