Sorry if this has been covered, I tried looking and couldn't see much though.
I quite fancy getting a large format camera for some architectural type photography, not really architectural photography as you'd think of it, but it's probably the only name I can give what I'm doing.
Basically I want the neg size of lf, the ability to sort out uprights and have them not converging etc, and I want the physical constraints that using lf will put on speed, number of exposures etc.
I could sort the uprights with a t&s lens but I fugure I can probably get a lf camera for about the same money and any excuse to add another (type of) camera is a good excuse right?!
Things I'm not sure of though,
Cheers.
- How universal are lensboards? Do I need to get a board that'll match whatever camera I was to buy? Is the whole always the same size or does that need to match the lens I buy?
- Film holders, as above.
- Do pretty much all lf cameras do tilt/shift/rise etc? I understand there's the folding (usually) wooden bodied type that probably don't? Would any monorail camera be able to tilt etc?
- Lenses, 90mm is wide for 5x4 right?
- Shutters, built into lens? Separate? Could be either?
- While I could use tilt to correct converging verticals, can I also use it to make them converge more?
- I have seen cameras where the front and the rear can tilt, shift etc, is a different effect achieved by say, tilting the lens board as opposed to tilting the rear board
Cheers.
