foodpoison
- Sean
Okay, recently bought some skyports and a 430ex.
I have them set up like so:
The cord in question is this one: Pocket Wizard Plug to PC Plug
The hot shoe adaptor in question is this one: Hama Hotshoe to PC Sync cord Adaptor
I have put the camera on manual mode, and put the skyport into the hotshoe of the camera. The skyport trigger is set on the preset channels, the firing mode set to 'all' (rather than group or off) the group is set to 1 (even though this is irrelevant).
I have put the flash into the hot shoe adaptor, set the flash to manual rather than ETTL, plugged the cord into the hotshoe via pc and the skyport received via 3.5mm jack.
I have set the received to group 1 (even though this is irrelevant), set the channels to the same as the transmitter, default, and turned the skyport on (I can tell because the LED is flashing).
Edit: The problem is, the flash isn't firing, no matter what I do.
I have no clue as to why they aren't working.
Yes, I've rtfm, and there isn't a lot in there thats any help.
Any thoughts or help on this would be really helpful.
But it's all fine now!
