How to meter with 400D
dwdave
As it says really.
Shooting in Manual for example - am I right in thinking that I just half press the shutter release and that gives me a meter reading?
Also can I just check up on what the * Button does as it seems to fire the flash and show FEL in the Viewfinder.
Only reason im asking is because Im considering getting a Sekonic Flash Meter and am looking around at meter readings etc.
Thanks All.
Sorry to be blunt bud, but all that's in the manual.
What do you want a separate meter for?
* is exposure lock, point to a dark area (e.g. sky), shutter half down and press & hold *, now aim at a light area and take a shot.. metering will come form the dark area that you first pointed at.
And if you are using flash, it fires the pre-flash and locks the exposure on that also.
Flash meter is usfeul in a studio if you have several lights to set up, but not essential. I wouldn't bother for just one or two lights - use the LCD/histogram. Meters are expensive - Sekonic 308S seems favourite these days, I'm very happy with mine, about £120.
You can download a PDF of the camera manual on line.
Sort of, it tells you whether you are under or over exposed...
If you look at the gauge in the viewfinder or on screen it shows...
-2...-1...0...1...2
You adjust the shutter or aperture until the indicator is at "0" this shows that the shot is correctly exposed in camera..
This is reflective metering but if you purchase a light meter this is incident metering but this is another topic....
:thumbs:
Almost - I think what you mean is the camera thinks it is properly exposed. If you want snow to be white you might want to take a bit of control back ;)
It was only the basics.... ;)
The camera meters for 18% grey so if you wanted to shoot white objects you have to overexpose by +1 or +2 stops...
For pure black under expose -1/-2
:thumbs:
thats better ;)
Actually though I prefer my snow slightly blue - it looks whiter that way :)
