In the past I have simply used a ruler held against the screen.Hi @Box Brownie
Actually, I am looking for something that can make it easy to measure images on the monitor screen.
Let me know if you need more clarification.
A ruler?Hi @Box Brownie
As I asked, if you explained reason for the requirement it is likely you will get more informed advice.Hi @Box Brownie
Exactly!I think you need to be careful as measuring an image on a monitor is one thing but if printed it possibly wont be the same size.
So I think it depends what you want to do and why.
Why do you want to measure an image on a screen?
On the surface of it, there is no answer.FWIW I don't ever recall your question arising on any of the various photography forums I member of!
But that won't be the same on other monitors of a different size or resolution to yoursYes, it's nearly like a ruler. But not a physical one. I need something that is easier than physically putting a ruler against the monitor. So, I can adjust the images on the screen and assure that it's 6 inches long.
You clearly(?) have a very specific (to you) requirement but unless you feel able to state the specifics of exactly what you are doing no one can guide you through your dilemma.Well, I know that it's odd for you all. But I personally have a few different use cases where I am currently putting the physical ruler on a monitor. For example, I sometimes want an image that is an exact dimension on the screen or to measure things on the screen to calculate proportions from online images.
I'm sorry I can see that it's becoming more complicated than I expected. There are so many online ruler applications available(i.e: https://ruler-online.net) and I have tried some of them. They are making my work a bit simple because I don't need to place the physical ruler. But it is still complex to measure images on these online ruler applications. I need something that can help me to do the measurements more simple and quick way.
Doing what I suggested above, an image 845 pixels wide is exactly 6" on my screen.
Thank you guys for your wonderful support.You have to have a known first... either a known object size/dimension of something in the image (comparing relative sizes in an image ), or the pixel pitch your display is set to (setting physical size on your display).
View: https://youtu.be/xXE7MBiWJIc
It will always be measuring the image in pixels because that's all there really is in a digital image. But it will output whatever known unit (mm, in, etc) you tell it too.But @sk66 can I change the measurement unit from pixels to inches in this software?
