I have just got planning permission for a outbuilding in my back garden, that I will use as a home studio. It will measure 6m x4.5m x2.5m to the eaves. I had been planning on building a brick/block building but have recently been looking at log cabins around the same size.
The major advantage for considering a log cabin type building would be the cost. Approx £5000 against £10-12,000. I know that there are some of you that use a log cabin as a studio and wonder if you can list any disadvantages, and if you had the chance would you prefer a brick building?
I have seen a log cabin at a local manufacturer that has the internal walls fitted with plasterboard and plastered and once inside you wouldn't know the difference. Obviously electricity will be installed this will allow convector type radiators to be used when required. Do wooden buildings retain heat better or worse than brick?
Any views or advice would be welcomed.
Thanks,
Nick
Thanks,
Nick
