I don't think you are getting high speed sync, not as we normally understand it. Not in a useful manner anyway.
You cannot achieve High Speed Sync (as Canon call it) or FP Sync (Nikon) with a studio flash. They work differently. It is possible with hot-shoe guns by strobing the flash rapidly, at around 50,000 per sec, just long enough for the focal plane shutter to complete its cycle. That way you can get flash sync right up to the max 1/8000sec and even beyond (with certain drawbacks).
The Hypersync feature of Pocket Wizards varies the timing of the normal flash pulse to exploit the small amount of leeway that exists beyond the camera's normal x-sync speed timing window. That way they can push 1/250sec up to 1/400sec or so, depending on the camera.
What you appear to be doing here is exploiting the long flash duration that is common with studio flash units. The total flash duration is
much longer than the quoted time. If you look at an oscilloscope trace, the flash peaks at a high level almost immediately, then falls away also very quickly to a much lower level but retains a long 'tail' of light that goes on for quite a long time, but at that very low light level. That's the bit of the flash that you are recording here - the long, low, flat tail. And it is not quite flat, just falling slowly, as shown by your test images being darker at the top. As a rough guess, I would say it's about a tenth of the brightness of the peak, something of that order, and uneven over the frame. Cameras with slower cycling shutters than your pro-spec D700 wil show this more.
You are able to make use of the tail in this way because the HSS/FP mode of the tiggering hot-shoe gun alters the sync timing away from the normal x-sync point, by which time the flash peak has passed and only the long, low, flat-ish tail is left.
It's interesting though
Edit: BTW, the slight reduction in x-sync speed you are getting with the Skyports is normal with lower end radio triggers. Only top end jobbies like Pocket Wizards have high speed processors that are fast enough to maintain the normal (optical) remote slave sync speed.
