My new nifty fifty won't come off the body. It's rotating, however not enough. Then clicks Babcock into place. Am putting moderate force through it, but with no result
I wouldn't force it too much, best to take it into a repair centre, they can remove it without doing any damage, if you force it you may well snap something inside.
At an educated guess the plastic mount on the nifty has broken hence it won't unlock for you Definately recommend using a repair centre and hope the lens is ok for you
I've had this, for me it turned out to be one of the little lens screws on that butting surface had slowly unwound until eventually it projected out enough to stop the full undo rotation.. My mate spotted this, so by opening a crack at the juntion because of the loose screw with a little gentle flexing, he managed to pull the screw back and away from the junction a tiny fraction and the lens turned off as normal.
Would be good to know for reference , was there anything maintenance wise we could all do to prevent this failure ?
Glad you got yours sorted though . Top service from Argos .
