Help!!
paulminus273
paul
I have just edited a load of images but this time I saved them as tiff files now when I convert them to jpeg the colours go c**p.
Is there a way to recover them, if so how Please
Srgb which I thought would mean that windows would display them at its best
You could possibly recover them from the memory card even if deleted. type in "memory recovery" on google and there are several listings to help. If you have formatted the card then this isn't possible, only if the normal delete of the card will work
Realspeed
I have still got the raw files and the tiff files but would like not to have to re edit if it is possible
The raw files should have the raw edits still intact, have you tried opening one of the raw to see how it looks? Also try opening a tiff in your software and see how it looks in there, it might be a disply issue rather than a fault with the tiff.
The tiff files are fine but every time I try to save them as jpeg the colours go c**p I am sure I am doing something wrong (I am saving srgb ) idiot saved strait to tiff and left the raw files as out of the camera
I am using cs4 but you got it right first time two monitor and one is way off sorted now thank for all the help
