hi folks
looking through the sony a6700 manual and was wondering if someone could explain, in simple terms the table about recording times
file format - how do you know what one to use, I take it you can specify what one you want in the camera settings
recording frame rate - again do you specify in the camera settings and if so how do you know or are these automatically set when you choose the file format
the sd card and time column is the only thing I understand
thanks very much
thanks very much
