HELP!! with template...
hi
if you want 6 identical
Try this
1) create 1 .
2) make the canvas resonabely large (wide)
3) select all
4) copy and paste 6 times
5) you will have 6 layers
6) select each layer then move it accoss the canvas clear of the others
7) save the file as psd
8) merge all layers
9) print with the print to fit option
this should work
Cheers Steve
Mark
The Panel script in script writer will do this. Set the page size to be the size of a bookmark and 1 horizontal and 4 vertical images then make them small enough. The software will automate it.
Looking for same idea myself. Thanks.
but maybe the preview mode is set to BW, other may know better. it is similar to ms publisher , the preview is BW
it may print colour,
Hope this helps
cheers Steve
