Doca
- Brett
I'm going to be a part of a presentation at work & for my part I thought it would be good idea to have a stitched collage (like panoramic view) of our production line running across the top of our display board to help explain the process to visitors to our stand.
I thought this would be pretty easy but it turns out not.
The production line is about 20m long and there is only about 1.5m of space in front of the machines. I used a 17-135 lens set at 17 on my 7D (widest I have) on a tripod & took shots every 30" down the line (moving the tripod).
At 17mm the very top & bottom of the machines is missing but that is ok.
I thought I would be able to merge and blend the photo's in photoshop to make 1 continuous picture of the line. Photoshop or any other software I have tried can't merger the photos.
The problem I think is the amount of perspective or keystoning? so wide at such a short distance makes merging not possible. Even if you try manually overlapping the shots it is not possible to get anything that looks right.
Does any one have any suggestions how I can make this work?
