Help with Filezilla uploads !
Zande UK
Sally Wallis
Hi !
I've been struggling for some 3 months now with a new computer - among other things, I installed Filezilla and at first all was well. Of late though (in the past week) I have been getting wild distortions and lines across images.
Uploaded with other .ftp programs, they work fine.
http://www.zandebasenjis.com/man by chipper.jpg
links to one I just put up as an example. I figured it best to request suggestions on the actual distorted image - if I put it on TP in the normal way, it'd probably be fine !
Thanks !
What do you have the Edit->Settings...->Transfers->Filetypes settings set to?
I'll look - I think you could have hit it ! I have Filezilla set up to .ftp to a number of websites and locations. Normally I upload images everywhere as binary but the database (almost 89,000 Basenji pedigrees) requires ASCII. Each 'destination' has its own settings. SOMEhow, these images may have been uploaded in ASCII
I think you are probably brilliant !
Make that definitely brilliant ! For some reason the settings, which in the past have been independent in different destinations - have decided that when one changes, they all do.
THANK YOU !
