Help with Canon ip8750
RuthH
Ruth
Hi!
I have just purchased this, print quality is great.
I read the spec as wanted to make sure it would print 8x6 (A5) and it said it did, however this option is not available when I send to print.
It jumps from 5x7 to 10x12....any ideas how I can get 8x6?
Many thanks in advance
Hi Ruth and welcome to TP
I do not know this printer but surmise it will help anyone who is able to advise if you gave more info as follows:-
What are you using Mac or PC?
How are processing your pictures or is it just text pages you are referring to?
What software are you using to send the file to print........and what if any steps taken to 'tell' the printer is is an 8x6 file?
In other words the what, the how and why is that you are not getting what you thought you expected.
FWIW in general terms you prepare a file for printing at a said size but to ensure it will probably t as expected you select the paper size within the printer properties.
PS A5 is not exactly 8x6........so does the paper type & properties list A5, as 8x6 is certainly not a standard print size!
Hi, and thank you for your response and advice!
I'm using a laptop to send to print on Windows.
Generally I edit in photoshop but don't usually specify print size, and I am able to select correct size on my Epson printer, however this isn't photo quality - hence why I purchased the ip8750
When sending to print, I get 12 options on the drop down menu, including standard 6x4 & 7x5 but then then next jumps to 10x12.
I'm sure it's probably user error (I'm not very tech savvy I'm afraid!!) and not the printer, but I would really like to produce 8x6
Hello Ruth,
if you're able you need to size your print in Photoshop to the size you want to print.
Depending on your camera the size will differ from other cameras.
However, as a pretty good guess your photos will have a 3:2 ratio
You can change this several ways, cropping mainly to the 8x6 which is a 4:3 ratio.
This would mean you will lose some of your photo unless you're able to increase the canvas size and then use content aware fill, but that's another lesson.
Simply changing the size from the 'edit-file size' menu option won't work very well as if you did resize to a 4:3 ratio without cropping you will end up with a very distorted photo.
So if you want the 8x6 size photo you need to consider this when taking a photo by giving some extra room around the subject to allow for the crop.
Once cropped even without resizing and or changing the resolution, the fact you now have a 8x6 (4:3 ratio) will allow the printer options, if available, to print at the 8x6 size you want.
The reason your printer options are jumping to a size you don't want are many fold.
mainly as mentioned the ratio is wrong, the ppi of the photo is too low, probably 72ppi giving you say a 30 inch by 20 inch photo that if you resized by changing the ppi would make the photo smaller without actually changing the size via the dimension drop down in the 'edit-file size' menu.
My advise is to learn the crop tool and crop your photos if you want a 8x6 (4:3 ratio) this will certainly go a long way to the printer giving you what you want.
Or just accept your photo ratio of (most likely) 4:3 and print to this size, 6x4 or 9x6 or 12x8 etc and then no cropping is needed.
This advise is far from complete Ruth as people will come along with the ppi vs dpi scenario as well.
Just remember ppi is screen resolution and photo file size resolution and dpi is print resolution.
DPI dot per inch and PPI pixels per inch.
dpi is what a printer prints and is pretty simple, it gets confusing when people mix the two and some people give the wrong advise.
ppi on a 24 inch full HD monitor will be different to that of a 42 inch full HD TV.
They both have the same resolution 1920x1080 that's width x height
However, the TV at 42 inches has bigger pixels (not dots) to cover the larger screen and so its ppi will be lower.
Not sure if it's relevant but my Canon printer wont print correctly onto CD unless I use the s/w that came with the printer, if I try to print out of Photoshop it is mis-aligned, apparently this is a well known "issue", although not known to me when I bought it. Is it possible yours wont print that size unless you use the supplied Canon s/w?
Matt
I don't think the Canon software has an 8x6 option, as you say there is 6x4, 7x5, 10x8 and a whole pile of other odd sizes but no 8x6
Thank you for the responses...
I'll try some of the advice above, but kind of nice to know it's not just me who has this issue!
I just checked on my Canon ip8750. There is an A5 option (no 8x6) and also a custom size option which you can set to any size you like, including 8x6. (I am on an iMac but should not make any difference).
If in Doubt contact Canon, have always had good results from them if I`ve had a problem.
