Hi all,
I have searched the forums and couldn't find any thread already present that could help me. So here is my question.
Recently my EOS 5dMark 1 started showing Error 1 and then sometimes Error 99. This happened on the 50 1.8 MK2 and EF24mm2.8. An on/off sorted the problem. Till it got to the point that when using the 50mm prime when the shutter button would be pressed the shutter would go down but would not come back up. The only way to get it back up would be to detach the lens. This would happen almost every single time.
I tested the lens on my 300D and it worked all fine. So I send the camera to the Canon repair centre in Glasgow. They mentioned a repair cost of £350 for replacing the whole mirror assembly.
My question is whether someone else has come across a similar problem and what was the remedy as to me £350 sounds quite a lot. Hence I am looking for opinion.
Kind Regards,
Zeeshan
Kind Regards,
Zeeshan
