Help with a weird one
stumac
stuart
Asking for a friend ....he has a Sony a73 and occasionally gets a shake mid clip ....it's quite a violent shake but his hand is steady .....the weird bit being it's not the whole frame and the shake happens generally but not always towards the edge of the frame .
Any ideas ?
Image stabilization/sensor tilt? Just a guess... I don't have the Sony, but I've seen where image stabilization reaches its travel limit and then resets to start again.
I've also heard of auto steady shot causing a wobble and setting it to manual doesn't.
But would the whole frame not be affected? This only happens on part of the frame
Has he eliminated the lens as a possible cause?
Does the lens have IS as well? Maybe they are confusing each other.
