- Dave
Can anyone with a plumbing mind help me?
We are lucky enough to own two houses. We were last in the second house about six weeks ago and everything, plumbing-wise, was fine and no one else has been in the house since.
We arrived here last week and when one of the toilets is flushed there is a loud sound(imagine a low note from a brass instrument or a foghorn) as the cistern refills which continues until the cistern is full. The sound is constant – no hammering.
I took the cistern lid off and the sound does not appear to originate there. The inlet to the cistern vibrates a little but as I feel further down the water inlet pipe towards the floor the vibration is stronger.
If I turn the wash basin, which is in the same bathroom, cold tap on, even if only for a couple of seconds or so, and then off, the sound stops and does not re-start. Leaving the cold tap running does not stop the sound.
The sound happens only with this toilet – all of the other taps, showers or toilets work perfectly.
If I reduce the flow into the cistern via the isolation valve I can almost stop the noise happening but I have to just about close the valve completely.
I'm puzzled why this is happening now when six weeks ago it wasn't and no one has been in the house since then.
Can anyone suggest a cause and how this problem can be cured?
Dave
Dave
