Help with a Circular saw tool blade
Mr Bump
From under the bridge
Sophia aka Paul
I have a Bosch 18v Cordless Circular Saw it came with the blade Bosch 2 608 844 565
it has worn out so i want another
I can't find one for sale, any thoughts if it has been superseded?
Bosch Professional 18V System Cordless Circular Saw GKS 18V-51 (Brushless Motor, incl. 1x Saw Blade (140mm)​
AI Overview
The Bosch 2 608 844 565 is an
Eco for Wood circular saw blade designed for handheld and corded circular saws. It is specifically designed to provide clean and fast cuts in all types of wood and wood-based materials.
Key Specifications & Features:
  • Dimensions: 140 mm Outer Diameter, 20 mm Bore Diameter
  • Kerf/Thickness: 1.8 mm / 1.1 mm (Extra-thin)
  • Teeth: 30 Teeth
  • Blade Material: High-quality steel with carbide tips
  • Application: Ideal for general woodworking, providing a balance between speed and quality of cut.
That specific blade has probably been discontinued and you'll probably either have to risk aliexpress (as linked above) or have to compromise with the teeth quantity or kerf if it has to be 140mm, unless you go with another brand. 140mm is a less common diameter.
Bosch won’t make their own blades, they’ll just buy them in and rebrand them. There shouldn’t be any issues with buying another make, just buy something of decent quality. Screwfix sell Trend branded ones in the right size which are ok.
yeah i kinda know that but i wanted the exact blade as i have got used to the saw with that one and it has been great.
i actually found it now its an OEM blade they ship with the unit and it was just hard to locate but i have one coming for £9 :-)
Get 2 or 3!
Get 2 or 3!
i actually might but the reason i bought the saw was to help a friend with a small house refurb and not sure i need it to be fair, also i bought a bosch sds 18v hammer beast which again is a bit overkill for my needs, however the tool have more than paid for themselves.
