chilli_vision
- Marcus
- No
Hey Guys,
Can you help. I am trying to workout how to both rim light and back light a subject to make the more 3D, i.e standout from the background or look less flat. I have been having a few issues in getting the correct exposure when adding a second speedlight behind or to the side of my subject. I exposure for my subject using say a softbox slight left of camera. Then add a speedlight behind my subject firing off against a wall to catch a circle of light on the wall behind his/her head.
Is it mainly flash power you use to adjust the exposure of the 2nd flash when back lighting, i.e. trying to place a circle of light on a back wall, or is it a combination of both flash power and the Inverse Square Law, i.e. moving the subject further away from the back light so that the light from the 2nd speedlightfalls within a smaller f stop than I am using to expose the subject, i.e. with a softbox?
Does the same principles work for say rim lighting when i am using a speedlight fired directly at the subject from say back left to create the nice halo affect?
Cheers for your advise
