HELP! recovering deleted photos..is it possible!!
ben_notts
Hi Folks,
I have commited the cardinal sin....
I was transfering 500 pics from my camera to PC..
Thought the transfer was ok...So i deleted all pics from my camera
Unfortunately.. only 135 pics were transferred :bang:
Is it possible to recover the missing photos??
Gutted if i cannot recover them...
however if that is the case..then it will be a lesson learned.... Albeit a painful one :(
Any help would be appreciated
Kind Regards
Ben
Thanks for the link :thumbs:
Now its time to do the homework
regards
Ben
just dont use the sd card till you recover them ben
Dave in Wales said:
'Recuva' by periform, it's free and works a treat.
+1 ...mate delete a folder and recovered them with recuva.
+1 for recuva, used it a few times & workes well.
If you only deleted them the data is still there, just the record of where each file is and its size have been deleted. If you formatted the card the data should still be there unless you did a low level format. The only way the data will be destroyed is if something else is written over the top of it. You might even find a few pictures from several 'deletes' ago on the card.
GL getting them back.
Another vote for Recuva - as an experiment I tried it on an external hard drive and found loads of old pictures so it should work for you if you haven't written to the card since.
Good luck,
Alan
:plusone: recuva, got back deleted pictures even after i'd written to the card.
Thanks for the info folks
managed to get them back with Recuva
:wave::wave:
Regards
Ben
