- Mike
Hi everyone,
Right, I am at a bit of a crossroads - I have googled the hell out of this and seem to just end up back where I started, so I figured I'd consult the collective tp mind
I find myself in need of a camera and lens, mostly for client video work - no brand loyalty, can be from any system but needs 4K 60fps - It's for interior video and images, so if it was reasonably ok for stills too, that'd be brilliant - only other requirement would have to be a wide angle option availability in the lens range (something between maybe the 17-24mm range).
One that kept popping up was the Panasonic LUMIX DC-S5 - I know this would have me sorted for the video requirements, but I've heard that wide angle lenses are few and far between for the system (hopefully that is incorrect) I have never used Panasonic though, so am a little hesitant, although I've found the camera and 20-60mm lens combo for £1500
Is there anything in the Sony, Fuji, Canon or Nikon camp that does 4K 60 without completely breaking the bank? An A7 Siii is out of my budget for this unfortunately, so I thought an A7sii would suit until I found it was only 4K30fps. I'd probably be fine with that usually, but 4K is a requirement and I'd like slow motion as an option for futureproofing. I looked at the XT4 and though it does 4K60, I read that it crops in to do so and that may limit how much I could fit into the scene if shooting indoors - please correct me if I'm wrong, I'd be perfectly happy with the XT4 if it could fit everything into a wide angle shot indoors
So, to sum up, needs 4K60fps with a wide angle option - anything between the 17mm - 24mm range and the abilty to capture half decent stills would be a bonus.
Thanks in advance to anyone that may be able to help, much appreciated
