Help : I feel like a fool : not anymore
ujjwaldey8165
Ujjwal
To continue my Hasselblad story / possible disaster
My 150 lens has landed this evening, while the deal on the camera fell through.
So somehow I am trying to check if the lens works propoerly. Its a C T* lens
Now I see that betwee 5.6 and 32, the lens aperture blades move. But when I am setting it to 4, and moving down to say 32, the blades are not mving till I press the white tab between the words 'synchro' and 'compur'.
Now that could be some sort of interlock provision; but my question is :
when the lens is mounted on a camera, does the aperture have to be cocked in someway, or that happens on its own.
Ujjwal
Give it a mo till someone who has a clue comes along. Although I have a Hassy I don't have a 150.
Good luck with it.
Try to change the shutter speed. My 80mm can't get some apertures at some speeds. They are not "compatible". I don't know how to explain better in english.
Thanks Ivo. I know what you mean; thats the EV range limits. No, thats not the problem.
I think its a interlock feature of the lens; but just want to be sure; so that if its a problem; I can return the lens.
Ujjwal
Now I know how to explain that :D EV limits, that's it ahah...
Hope that it isn't damage or something. I'm reading my 500EL/M manual to start shooting with it too..
This isn't all manual so I have to learn how to work with the motor...
Really feeling like an idiot....being stood up by the seller and buying a lens before I got the camera. Just serves me right.
I have to get a body this week end, as long as it works I dont care.
Thanks for the support Ivo...
Ah, figured it out, finally
The button I am talking about, between the 'compur' and 'shutter' is the DOF button
Bizzarly enough, the way to do DOF is to set the f stop; them press this ; and the aperture stops down. You then have to go back to full open ( f4 in this case) to open the aperture; and then set it back again.
So this part of the lens works fine. the rest reamins to be seen.
I dont feel like a fool anymore; but its one evening wasted staring at the lens.
Ivo, thanks again
Hey, even I know what you mean now, good luck with the search.
Cool. I think it's hard to get non working Hasselblad gear! haha.
My EL/M is great. Already put one Provia 100F on it and tomorrow I'll do some tests.
edit : by the way, what I said in my post above is just my speculation; the a result of staring at the lens the whole evening. I am pretty sure its right; thats the only possible logical explanation. But a confirmation will be welcome.
If not, i'll confirm once I get hold of a body
if it helps i have the oppsite camera and no lens !!!
Finally, I have got one. Should be with me in the next few days.
Thanks to the seller who stood me up, I got it at a great price ( or so I think)
Now I need a day out with it
Enjoy it and with your newly found taste for home developing, can't wait to see the results.
Hassy's just feel so right in your hands. :) Wish i could justify buying one.
